jfarrugia98
- Sep 5, 2016
- 21
- 2
- 3
- Location
- Penrith
- 09 VE SV6 - 08 VE SV6
Today I decided to take on the transmission service as the car is approaching 150,000km. A while back I needed to replace the radiator and upon doing so i noticed the fluid coming from the transmission was a dark/cloudy black colour and assumed the fluid will need changing soon.
So today i’ve taken the car to a mates house, put it on a pit, got underneath and began to attempt removing this drain plug, the plug needs a T45 bit. One snapped sidchrome spanner and ratchet later the damn bolt has not budged. Only on the third attempt with the 2nd spanner, i’ve somehow completely stripped the thread of the bolt and am clueless as to how to get it off now.
Upon buying the car 2-3 years ago, a wiring harness had fallen loose from the transmission, getting caught in the drive shaft and digging its way into the rear transmission oil seal. I had taken it to holden to get it fixed, where they replaced the seal and the harness (In a very bodgy way using cable ties and $1000 later but so be it), and i also requested that they topped up the transmission fluid as some had leaked. My opinion is that they have tightened this drain plug way way way too much, excessivly more than the mere 20nm my service book suggests.
So long story short is there any way of me being able to remove this stripped drain plug bolt? Thanks in advance.
