torch
Banned
yes along with increased oil flow goes decreasing oil pressure, sometimes all that high oil pressure indicates is that the oil flow is being retarded, as when the oil too thick/cold, or not even happening at all, ie bypass valve being activated.+ Just by the way, as bearings wear and clearances widen, the oil does flow faster, out of the wider clearances = loss of oil pressure. Might not be an advantage.
Its a fairly cheap exercis for engine manufactureres to put oil pressure sensor at the output of the oil pump to detect whether the oil has stopped flowing in the system. Deciding what is happening inside the engine just by the use of this one sensor is very limited.
Im fairly sure the vt specs for the v6 in the manual are 10W/30?
