HEXEM
Thanks Phil.
So all your issues are now (finally) solved?
So far so good...
Thanks Phil.
Ok; L98 is the engine that MANUAL V8's and AUTO V8's had up to 2009 (not sure when) THEN the MANUAL V8's had the L98, Active Fuel Managment AUTOS had the L67 engine, however once the series 2 came out both manual and auto used the same L77 engine, the manuals had AFM deactivated. They had different lifters and cams. So if you have a series 2 you have an L77 if you have a MANUAL Series 1 or pre 2009 auto you will have an L98.
If any of this is wrong I'm sure Phil of someone will correct me
