6 Speakers to 4 channel amp
meady_183
30
Victoria - South East
VX II Berlina
Hi all,
I currently have 4 X mb quart 4 ohm speakers in the doors powered by a 4 channel amp.
I would like to add an extra two 6x9 speakers to the parcel shelf.
My amp is 2 ohm stable.
Should I wire the door speakers in parallel to share chan 1&2 on 2 ohm and have the 6x9 on channel 3&4 at 4 ohm
OR.....
Have the front speakers on 1&2 @ 4 ohm, and run my 6x9 parallel with the rear speakers on chan 3&4 @ 2 ohm.
I'm thinking option 1, as getting max power to the 6x9 would be advantageous? Just after some opinions.
wraith
Hand over the dog bikkies
Demonicaland
VX V6 Berlina. 2003 VW Passat
You don't need fully sick 6x9s. Running 6 speakers off a 4 channel is just asking for trouble.
EYY
VS Statesman
Use another amp for the 6x9's.
Oval cones are far less than ideal and allow much more distortion than a round cone. Just something to think about :p
meady_183
30
VX II Berlina
How about running the 4x door speakers off of channel 1&2 and bridging 3&4 for a sub?
wraith
Demonicaland
Same issue. 4 channel amp is exactly that. 4 channels. When talking about speakers your talking Front Left and Right. Rear Left and Right. That's your 4 channels. There are 5 channel amps out there that will do what you want.
