6 speed spigot bearing ???
dooda
Hi Everyone
I have a question regarding my new 2004 vz sv6
I bought it with a stuffed clutch and have since replaced with a single mass flywheel conversion.
Now when i removed the gearbox i found that the input shaft for the box did not have the small extension on the end of the shaft for the spigot bearing ?
It just ended flush with the spline. The clutch kit came with a new bearing
I have put the box back in and the car does seem to drive fine but does get a groan from the gearbox on take off under load.
I am highly concerned about the shaft not being long enough or have the short piece to fit into the spigot bearing as i have never seen a manual box that did not require a spigot bush/ bearing
Anyone seen a t56 with a short shaft like this ? or know why it may be different etc etc?
Thanks all
jake383
05 hbd vz calais
ay7 gearbox does not have a spigot bearing. you are getting gear box groan, noise, chatter because you have changed from a duel mass flywheel to a single mass flywheel
dooda
Thanks Jake383
Perfect answer mate :)
So there is no way to eliminate or decrease the groaning noise? or is that just a trade off with converting to a single mass flywheel ?
thanks
jakvz
toowoomba
vz thunder
Same with mine, got put in last week and was thinking the same thing
jake383
05 hbd vz calais
that is correct you can only remove the noise by changing back to a duel mass flywheel. But as most people say they just put up with it. I am using a after market duel mass kit but with the power im making i think il be changing to a single mass
andyman
The Only 6sp VZ Wagon
34
Orange, NSW
2012 BT50 4x4, 84 Hilux 4x4 & 05 Husky TE450
you could probably try a thicker gearbox oil, it could possibly make it stiffer to shift gears when cold though
