60 amp fuse keeps blowing
Discussion in 'VT - VX Holden Commodore (1997 - 2002)' started by HEMI TAIKATO, Nov 3, 2018.
  1. HEMI TAIKATO
    HEMI TAIKATO New Member
    TAURANGA
    98 HOLDEN VT COMMODORE
    i need help with this issue i have disconnected amp an sub checked voltage regulator an still keeps blowing i cant find any wires that are earthing out help please
  2. lout
    lout Well-Known Member
    Langwarrin Victoria
    VX Executive S2
    which 60A fuse
    NeddyBear and Lex like this.
  3. HEMI TAIKATO
    TAURANGA
    main fuse
  4. HEMI TAIKATO
    TAURANGA
    hapens wenever i replace then turn key over
  5. HEMI TAIKATO
    TAURANGA
    ive tried disconnecting head lamps radio an amp n sub
  6. Nut Kracker
    Nut Kracker Donating Member
    Echuca Vic.
    VT SS 304ci (195i)
    Well, seeing everything after the main 60 amp fuse is protected with fusible links and smaller fuses that would blow first
    if anything was wrong. I'd suggest it could be the ignition switch that is causing it to blow.
  7. lout
    Langwarrin Victoria
    VX Executive S2
    what position on the ignition switch
    accessory
    reds
    cranking
  8. HEMI TAIKATO
    TAURANGA
    only wen it goes to crank otherwise all works radio etc
  9. lout
    Langwarrin Victoria
    VX Executive S2
    remove fuse 13 and 14 and start relay
    then recheck
    hope you have plenty of spare fuses
    then refit fuse 13 retry
    refit fuse 14 retry
    then have a really good look at the wiring around the starter motor
    then refit the start relay
    retry
    as soon as the fuse blows no need to test any further
  10. HEMI TAIKATO
    TAURANGA
    ok thank you so much appreciated mate will do tomorrow as is getting dark out will reply wen done cheers agen
  11. HEMI TAIKATO
    TAURANGA
    and im asumming if it does blow after whats suggested that faulty starter or ??
  12. lout
    Langwarrin Victoria
    VX Executive S2
    my bet is it wont blow until you refit the starter relay
  13. HEMI TAIKATO
    TAURANGA
    Hi i done all as above replaced ignition an new starter but it still blowing when it was first fixed was statting fine week later same prob any ideas
