vombil
hey guys picked up a 6L and knew it had a bit of noise on cold start - seller presented it twice, both times he had hit the key briefly.
weird thing is that I drove it nearly all day I bought it then cold started it the following morning or even two mornings later and no noise.
I've left it a week now and crikey - it's quite the noise! - so I suppose lifter bleed down is the most logical explanation however -
the noise starts loud and has a bit more of a knock/tap than a slap, rattle or tick.
The noise was shocking for about 3-5 seconds - the knocking part - and then the noise became a bit of a slap/tick? and did get progressively quieter over about 30 seconds and was gone after a minute lets say. Whisper quiet when right up to boiling hot with fans on etc
I don't know what oil it's running. I'm going to drop oil and check for bearing material which I've experienced in a 5L VS with big end knock. I'm thinking I'll go to a 10/30. It's a very very clean car with 140 kays and has intermittent service history in the book but does not 'breathe'a puff of any blow-by at all and the underside of filler cap is really really clean.
So how will I determine if it's a fractured oil pump gear, lifters, a big end or just garden variety slap/gudgeon noise etc? - without pulling it down
thanks guys
thanks guys
