vombil
Did you know that you can drive into SuperCheap and ask a tech to either check the oil pressure or show you how to check it using OBD it for ~$20 plus the ELM?
Without either a video of the event capturing the noise in some shape or form or any hard data in black and white, is not just anyone’s guess what it is, it’s logically a waste of time.
First step is to pinpoint where the noise is coming from and why, to do that you need to gather something to work with as above - video and or oil pressure reading.
I mean could be any moving part and not even part of the engine!
So i did the accel to the floor and cranked maybe 4-5 revolutions, two times. There was no knocking and no lifter noise when it fired - just a pretty mild piston slap that cleared completely after about 30 seconds and did not get louder or return with light increase and stabs of throttle. I'm not sure this a great test to isolate the lifters as the cause (which ive read elsewhere as well) of the noise as it would also lube the cam and crank so masks bearing/oil pressure and or oil pick up issues as it's priming the whole engine.
