Hi I came across your post whilst I was looking for information on the required electrical interface between an LS1 and 6L80E in a cross 8 Crewman. I am currently getting pricing on manufacturing the required adaptor housing and the stub shaft between the 6L80E and the transfer case. This housing will leave the transfer case in the same location in the vehicle, so that the drive shafts will not need changing. It looks like the transfer case mount may need a bit off a grind. Did you end up finding out any reliable information on a stand alone transmission controller. Wholesale Automatic Transmissions in Victoria, have a Compushift controller and I have requested info from them, but to date they have not responded. I am also working through what to do with the 4L65E TCM and its interface with the BCM and ECU. I am thinking that I might just get a manual tune on the LS1, but I want to make sure the CrossTrack system still works, I only use the car for charity rally's and the cross track is invaluable. If you are interested let me know and I will keep you in the loop. Regards Clive
