9 Speed Auto
Panzer23
ZB RS Liftback 3.6
Does the 9 speed auto, in both the 2 Lt & 3.6, start in 1st or 2nd gear when in drive?
Anthony121
VF SSV Redline MY17 & VF Director
It should start in 1st.
try this with the 4cyl. drive the car around 20-30 Km/h then hit the accelerator to the floor and release and then do it again holding to the floor. Very interesting!
Panzer23
ZB RS Liftback 3.6
Thanks Anthony121. I'm looking to buy a V6. It would be a waste if it didn't start in first.
VFRDLN
ZB CalaisV Tourer
For us V6 owner's what happens? Does the trans go into fail safe or thump hard? Or does the dash light up with a message asking WTF are you doing?
VFRDLN
ZB CalaisV Tourer
Checked mine this morning and can report it took of in 1st when cold but didn't check after that. Modern autos will skip gears though at times because it is not efficient to go through every ratio every time. If you have no load in the car 1st probably isn't required most of the time. While driving it is hard to count the shifts as they are seamless at times. If using the flappy paddles you will never be able to change better than the computer and they are useless unless you want to hold a particular gear for whatever reason. If you use the paddles there is a shift arrow that tells you what gear to select and there is no way you can keep up with it.
Anthony121
I don't know know if the V6 does it. Can't remember trying it in a V6.
