90mm or 100mm throttle body
eaton v8
my little sleeper
gladstone qld
vz 6l auto 239cam 3.9diff
any one know of a 90 to 100mm throttle body that is compatable and will accomodate all the parts and workings for a vr throttle body like the tps and the idle control mabey even the vacume lines????
eaton v8
my little sleeper
gladstone qld
its to put onto the blower to give the roots more air . if i can get more air to it with a 90mm its ment to give me more psi
eaton v8
my little sleeper
gladstone qld
is the star a single or dubble throttle
stocky
ooh ok. forgot about the blower. i dont think there are any that big. the biggest a normal v8 throttle can go is about 70mm. all the 90mm ones i have seen have square flanges
eaton v8
my little sleeper
gladstone qld
i can deal with that problem steel is what i play with as a job ill just ad a bit of pipe of to the side like yt for there m90 and put a flange for the square tb
MACE
You would probably be better off using an LS1 throttle body and modifying it to suit. At least this way it would work out cheapest for you, considering you'll still need to modify the elbow to fit any larger throttle body. While you at it you can always an extra couple of vacuum fittings ;)
