OUTLRD
hi
I have a 91 VN V6 manual wagon, just done a rebuild on the motor with stage 2 cam and chip by crow cams... absolutely everything in the motor is new from bottom end to top. new injectors and o2 sensor.
The problem I'm having is when i start it, runs and idles as it should, as i take off the engine light comes on, when i back off the throttle while still in gear, for example 100km/h to 80km/h the light turns off. come back on throttle and it comes back on. car seems to run fine, no noticeable power loss. now after the car has warmed up a bit, it wont return to idle when i pull the clutch in or out of gear. i have to keep tapping the throttle to keep it running. doing my head in, literally changing part by part and cant find the problem. if anyone could help? cheers
