94 VR not idling in Park & Neurral
theslippery1
Yamba
94 VR Commodore Executive
I have recently replaced the water pump, CAS, Power steering pump & the harmonic balancer & now I'm having trouble with the idle in Park & Neutral is there any sensors that I need to look at ? I'm not a novice I have worked in a mechanical workshop for approx. 3 years , just don't know everything about the 3.8 V6's Any suggestions would be appreciated.
thanks theslippery1.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
theslippery1
Yamba
Thanks for the heads up had thought of error codes after posting & went & got them . I will check them when it stops raining .
Cheers theslippery1.
hako
Donating Member
77
Toowoomba SE QLD
VS11 BT1 V6
Also mean't to say check the vacuum hoses that go to the throttle body for splits or if they've come adrift.
theslippery1
Yamba
Ok cheers again was going to clean the throttle body tomorrow & check the IAC let you know the outcome
theslippery1
