My situation was atypical because it was the result of the modifications required to interface the PCM with the Motec ECU/manifold that was installed on my 383 VS Calais.
Nevertheless it took years, and the unnecessary installation of many TPS units by myself, before the real source of the problem was identified and fixed. I didn't fix the problem personally, so the only advice I could give is to perhaps get the PCM connections checked out by an auto electrician.
Before that, the other thing you could possibly try, would be removing and re-seating each of the two PCM module connectors a couple of times to make sure there is a good electrical connection. Diagram attached below:
