'99 vs statesman knock noise in front r/h
Discussion in 'VR - VS Holden Commodore (1993 - 1997)' started by pjdm1980, Apr 14, 2009.
  1. pjdm1980
    pjdm1980 Shut up Jr I'm thinkin!
    Geelong, Victoria
    E1 GTS BUILD NO# 007, GQ Patrol.
    Everytime i back out of my driveway (lowered car and moderatly steep driveway) i hear a pretty loud knock/clunk from the right hand front (i think) but this is the only time i hear it and it just had its wheel alignment one month/2500klm's ago, there is no shakes/shudders/abnormal wear.
    Any ideas i'm going to have a look tommorrow:bow:, as it has had a wheel alignment i assume they have missed something small and it hasn't effected any other part of the car while driving?
  2. Tas_HSV
    Tas_HSV New Member
    Hobart,TAS
    VR HSV Clubsport
    Do you have adjustable strut tops?Bearings are worn on my Kmacs and it makes a knocking sound when turning at parking speed....
  3. pjdm1980
    Geelong, Victoria
    standard ones
    No, their just the standard ones with the strut bolting to the metal plate that sits in the strut tower.
  4. GAMBLR
    GAMBLR More trouble than u think
    Whyalla (yawn), South Australia
    '04 VZ Calais LS1
    also check your strut top bearings and cases. i lost a couple of the ball bearings out of mine, didn't think too much of it and next thing i knew, the strut shaft had come up through under the bonnet. the bearing housing has too much pressure on it and breaks. but this was knocking in mine for ages.
    Another cause could be the swaybar link and the bushes associated with them. i just replaced mine and all noises are now gone. my dad's VT has to be done soon as his is the same. common failure on all commodores as soon as ya play around with the front suspension.
    hope this helps
    CC
  5. pjdm1980
    Geelong, Victoria
    Looks like it was the link bar bushes they were as flat as pancakes!
    Thanks for the help.
  6. GAMBLR
    '04 VZ Calais LS1
    main cause of my front end noises. glad to hear u got it sorted. did u replace the metal pin rod as well?
  7. pjdm1980
    Geelong, Victoria
    No, should I?
  8. pjdm1980
    Geelong, Victoria
    _____________________________________?
  9. GAMBLR
    '04 VZ Calais LS1
    depends on if it needs it. like my dad's are all bent on his, but mine weren't. but cos mine came in a kit, the pins and bushes, i replaced the lot.
    it helps if you're lowering it, as the aftermarket ones are thicker and can take the extra pressure from the car being lower. this is a common problem for all commodores VN onwards with lowered front suspension.
