maximus300
Hi let me first start with the problem then what I have done.
VT was fine for about 3 years she used to crank slow for the first crank then fire up no problem i was told this is common with VT's.
now she in the morning sometimes she will fire up straight away and then stall only to just crank away and not start or fire at all. then if your lucky she will just decide to start at random and when she is running has no problems at all. I had it scanned and 2 major faults came up for the (crank sensor) and the (Cam sensor) both I replaced with no change to the problem. also on occasion the engine light and traction lights come up ?
So what to do ? I don't think its the fuel pump as when she is running its all fine and not the 2 sensors as they were replaced.
I appreciate any help thanking in advance.
