A cheap and quick fix to replace evap rubber elbow behind throttle body
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Benboy, Dec 31, 2017.
  1. Benboy
    Benboy Well-Known Member
    Hill River, SA
    2007 SVZ Wagon
    Often read of members having concerns with the cost of replacement of the evap solenoid valve feeds air from the canister to the right angle connector at the left front just behind the throttle body on the Alloytec.
    You can carefully remove the rubber angle, note that with age it is very poor quality and corrodes over the years.
    Holden charge about $70 - $80 for the complete line to the manifold intake. It is not possible to just buy the elbow.
    MY FIX: go to an automotive wrecker and buy some spark plug insulators. You know they used to be on the older cars with exposed spark plugs and connecting cables to a Distributor. They might cost you $2.00 - $5.00 each a LOT cheaper than HOLDEN can supply for. They fit the intake and hose perfectly. To extend their life, get some 'Magic Silicon Tape' (self amalgamating) and wrap around the rubber. Helps it stop perishing/cracking.
  2. harrop.senator
    harrop.senator Well-Known Member
    perth
    vr senator 355, vu 5 speed l67
    Done this at work a few times to avoid having to charge the customer works great . Never thought to actually mention it to people one of those fixes found scrambling for an alternative round the shop so ten points gryffyndor for letting every one else in on it!
    Murray Hill, losh1971 and Silverbird like this.
  3. Silverbird
    Silverbird (Blake)
    VZ Executive Station Wagon
    What a pearler of a fix. I'll keep it in mind for later use if needed. Thanks and Happy New Year!
  4. VS_Pete
    Be a great idea to put one or two in the car.
