revster
- Jun 22, 2014
- 545
- 223
- 43
- Location
- Adelaide
- 30th Anniversary HSV Senator (Gone) MY19 Golf R
For some reason I went and had my tune checked by another SA company. Thank god I did. The fuel trims were maxed and a mess of other stuff including detonation that was causing the puter to pull timing and a surge under certain circumstances. I was happy with it. Just goes to show. The first well known tuner usually takes about 25-30 mins on the dyno. Today(another well known tuner) 2 guys spent 3 hours working on the tune and test driving. They changed 100s of cells rather than taking the easy way out and leaving it to the ECU to make up for errors.The auto is so much smoother, the throttle more sensitive. A/F ratio now perfect.Overall a much better experience. Numbers were a bit less but different dynos on different days with 98 fuel which can vary but I am not fussed about the numbers. Flat torque line from 2800 to 6000 rpm.
