ABS and Traction indicators on simultaneously!
jkirpy
VT Executive V6
Hi peoples,
When i start my car my abs light and traction ligths comes on....Why is this happening...any help would be greatly appreciated...
minux
Infidel Bear
ABS Fuse could be gone, ABS module could be dead, check the fuse in your engine bay :)
deserthead
Cairns QLD
VS III l67 Column Shift Ute
Also the connector on the module may be dirty unplug it and have a look.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
do the lights stay on?
if so there will be a fault in the system disabling it, probably a wheel speed sensor at a guess
Rob
jkirpy
VT Executive V6
It only comes on somes times when i start the car.....when it does come on its stays on for the rest of that trip?.....i dont think its the fuse if it happens on a on and off basis.....weird...
deserthead
Cairns QLD
Yeh mine does the same, it'll come on randomly and then once the ca ris turned off and restarted it usually is gone. . . . .
Doctor Bob
Grandpa
Retired
get the code checked, this will be a good indication to where the fault is, until then its all guesswork
Rob
deserthead
Cairns QLD
Hey Rob, will bridging out the terminals under the dash bring up the code, or will it have to be hooked up to the computer at a dealer?
Doctor Bob
Grandpa
Retired
it is possible i think to flash codes from the ABS, ill have to look it up, easier to get it checked at a dealer
deserthead
Cairns QLD
Nice thanks mate, might get it looked at oneday.
