ABS ESP plus other error codes
Jharv588
Rockhampton
Ve Commodore
Hi guys. Hoping that someone else may have experience with this. Sorry if it's already been posted before. But I couldn't find another thread.
Recently my abs and esp started to play up giving me warnings on the dash. After searching I'd assumed that it must be one of the rear sensors as they seem like a common fault from what I'd read online.
But as per the Supercheap auto scan report it's showing both of the fronts (plus more) I haven't had a chance to check the resistance of them yet. But I'm finding it hard to believe that both front and left sensors would stop working at the same time and that it may be something more serious. The other errors on the list lead me to believe that it's something else as well. Possibly the BCM or some other module?
Thanks in advance.
VS_Pete
Donating Member
go the cheapest replace both wheel-sensors.
Reset codes.
See how it goes.
How is the battery??
How many klms
Jharv588
Rockhampton
Ve Commodore
Have to chance the wheel bearing hub assembles to do that. The front hearings both still feel pretty good.
Battery is a few months old and is reading fine with car on and off.
It's a series one but only has a 127k on the clock. Believe it sat around for a while before the last person bought it and sold it to me.
VS_Pete
Donating Member
Sounds like they left it for you.
Hope it works out mate good luck all the best.
Please keep us updated.
ChRiDDa
N/A
VE SS-Z Sportwagon
The better half had a series 1 that threw up identical codes
The rear abs loom was broken and the throttle body was knackered (even though the car drove fine)
You able to source a throttle body from somewhere/someone to check if it corrects the issue? Very simple to change but you wanna know that it’s the cause of the problem before you go and drop $300 on a new one
Jharv588
Rockhampton
Ve Commodore
Sorry. Only saw this now. Thanks for the feedback on that. Quite a strange thing to cause that. Just after I'd ordered a replacement abs module (after being advised that's likely the cause) the issue stopped. The module arrives tomorrow lol. I might have to look at throttle bodies online as well. Don't have one I could test out unfortunately. But for the meantime while it's working ok I'll just leave it be. No idea if it's connected but I switched from E10 fuel over to 95. Maybe it doesn't like the E10.
MYVESSV8
Brisbane/GoldCoast
VE 6LT M6
wheel sensors, rear loom are cheap, dont think abs module (expensive) is though and more than likely not the problem, get battery load tested to be sure
