ABS Fault VZ V6
Discussion in 'VZ Holden Commodore (2004 - 2006)' started by Brett.t78, Sep 16, 2011.
  1. Brett.t78
    Brett.t78 New Member
    Altona North
    2005 VZ Executive 3.6lt V6
    I have an ABS Fault coming up on the Dash, and it won't allow the car to start. I have checked the ABS fuseable link and also disconnected the battery and re-connected after 5 minutes with no success.
    Also occasionally the SRS Airbag warning light comes on.
    Has anyone seen this before ?
    Any thoughts would be helpful.
    Thanks
  2. azazeldeath
    azazeldeath Donating Member
    Welshpool Vic
    VK Holden Commodore Wagon w/3.8L Buick
    Once but I hope it isn't for the same reason, when my LSD got replaced I stupidly went to a mechanic, turns out they didn't put the passenger side bearings in right, the ABS module managed to hit the housing a few times and break. It then made the entire wheel wobble once my computer noticed all that happening it wouldn't start again.
    It took the mechanics ages to get it to start even with a tech-2 (I am happy about that, they screwed me around alot I am glad their job wasn't easy).
  3. Iconic
    Iconic New Member
    Central Coast, NSW
    VX Calais LS1
    The battery might be flat or near abouts.
  4. richardpalinkas
    richardpalinkas Blown Alloytec
    Gold Coast
    Raptor Impulse VZ SV6
    abs fault usually comes up when the battery is near dead. happened to me, replaced battery and havent seen it come back
  5. colin-commodore
    colin-commodore New Member
    Bunbury
    VZ SV6
    Charge your battery mine did it aswel and layer on it came up with more faults. Charged the battery and was all good :)
  6. vzjudd2333
    vzjudd2333 New Member
    New south wales
    VZ commodore wagon
    mines got same problem but still not starting just trying to start but wont fully kick??? ABS FAULT & SRS AIRBAG KEEP COMING UP
  7. suckmywake
    suckmywake New Member
    WH Statesman
    How did you go did you sort it as mine is doing the same thing.
