VZ 06 V8 LH ABS Fault.
Guys, Whoever as many before and after will follow and look. Have had a traumatic day. Finally tackled soldering a bridge across my suspected ABS Lead socket. Twisting and shoving this lead together has switched off the ABS warning for varying amounts of time and travel. Thought/thinking after numerous LHF ABS Lead changes (over 3-4 years) that it must be in the body harness component of that wiring coupling. I fitted a wiring bridge and ABS fault was off till I tried it on the road. after much panic and frustration I decided to a LH ABS lead that I scored of a roadside VE wreck. ABS Fault was still on. I hooked my AUTEL up and looked for codes/faults and there were non. Roadtested as well as turning vehicle on and off and no FAULT Code. Thank you Lord! was in near tears. I thought ABS Fault was going to be permanent. Tested again just then all good. Moral is swap the lead numerous times with different ones! I have a small set but this one had never be fitted yet. On this issue, I have done everything BAR swapping out the whole wiring harness, (And I have one). I have done front wheel hub (sealed ABS) assemblies, swapped ABS Modules and I I have a couple model specific spare, just in case. Believe me I have done everything. These Crewmans are year specific as well. Various V8s Various year specific modules required as well, as best I know? I had tried and returned 2nd hand ABS modules from ebay which I could prove were faulty. I purchased a Same Thunder wreck and have all the important modules if need be. The place that opens and sorts out/repairs the earlier model ABS modules say that the 06 VZ model cannot be repaired. They looked at mine anyway could not fault! So with all these spares this one LHF ABS intermittent fault is a problem. There is nobody at all who can fix issue. Is there any resolutions of ABS faults in the Posts? Year specifically 06 Crewman V8 SS Thunder? Let me know if so, VY different as well. My fix today seems once again the changing of the lead LHF. Lets see how long it lasts. PS I did the same initially driving getting sensor results on an AUTEL. No irregularities observed.
No matter what I have done before the LH Lead has been the thing that worked got her reliable again.
Will keep you posted RE 'Fault Warning gone' how well it lasts!
Hope this has been helpful.
Starz
