i Looked at injectronics, but they can only repair, they dont have one to give me >.< i have found one but it hasnt been tested so it could be faulty too. i have someone chasing up one for me in QLDironically i had a 590 sent to me when I had a broken one, it did not work so I returned it.
if it helps i used online wreckers and did eventually find the one I needed, but this was a while back.
If it also helps you can get these reconditioned, they slice the lid off and redo the connectors. (there are ridiculously thin wires - think human hair). But they normally do like a reco swapout not reco your unit.
Unplug the ABS should work just fine, but you will have the warning lights on, no traction or abs till you replace it.Have a question for you, just had my A/C regassed but the compressor wont cut in when the intermittent abs module fault lights up. i am chasing one now, but i have been told the ABS module shouldn't be the cause as they are on different circuits?
any thoughts?
i do know when the fault kicks in my temp gauge also doesn't work
yes i do know that, but it wouldnt fix the A/C problem. found a second hand one to put in till i can buy a new one.Unplug the ABS should work just fine, but you will have the warning lights on, no traction or abs till you replace it.
yeah saw it and promptly bought it Thanks heaps, its now fixed, going to buy a brand new one with next tax return
Hi all,COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 NO TRACTION CONTROL 0273004219
COMMODORE VT-VX V6 & V8 3.8lt & 5.0lt V8 TRACTION CONTROL 0273004348
COMMODORE VT-VX V8 5.7lt GEN III 0273004389
COMMODORE VY V8 5.7lt GEN III 0273004962
ADVENTRA VY V8 5.7lt GEN III AWD 0273004989 – Replaces 689 389 50725 7 -I am pretty sure this also fits Cross 8
COMMODORE VY V8 5.7lt GEN III 0273004590
COMMODORE VY V8 5.7lt NO TRACTION CONTROL 0273004588
COMMODORE VY V6 3.8lt 0273004589
COMMODORE VZ V6 3.8lt 0265800318
Thanks for that, will keep it in mind as I go shopping for one.it's possible it's interchangeable with 389 and 590 as I know for a fact you can use both on the VX 5.7
