Abs problem 99vt
Upthevseriers
27
New Zealand
99 vt wag 3.8
Hi guys new to the page, had my 99 vt wagon in for a wof and has failed on the abs light staying on, has been on for some time have no idea why no other lights come on at all ( don’t have a traction control button) I wouldn’t have a clue abs so am a bit lost on what exactly to do etc, thanks in advance for feedback and advise
_R_J_K_
Zenki S14
Well, first thing to do would be to check the ABS fuse.
Jezza
Now with LS1 power
South Australia
WH Statesman International
The most likely cause of it will be that the ABS module has stopped working and will need replacing. The easiest option will be to get a wrecker to assist getting a replacement and then having a mechanic fit it. You can get new ones but they'll be quiet expensive compared to 2nd hand ones.
The ABS is the Anit-lock Brake System so when you have to jam on the brakes hard it stops the wheels from locking up which causes the car to take longer to stop. A failed ABS if found during a crash could potentially void insurance too if it's been known to not have been working for a while.
Upthevseriers
27
New Zealand
99 vt wag 3.8
Cheers mate was told that just wanted another opinion, will get onto getting another module
lout
61
Langwarrin Victoria
there would have been a code which would tell you or your mechanic where to test
BlackVXGTS
Melbourne, SE
Display your ABS error codes using the info in the link below:
