ABS/Stability fault
Sickbananas
35
South Africa
2010 VE SSV ute
I get this fault code and from what I understand it could be either the wiring harness or wheel speed sensors on the rear.
Is the harness one piece for both left and right?
Can I assume this is isolated only to the rear wheels?
For safety sake, I will order the harness(s) and speed sensors, can someone tell me what the GM part numbers are for these?
2010 SSV VE ute
thanks in advance
ChRiDDa
N/A
VE SS-Z Sportwagon
Yep - sounds like it and it’s a common problem amongst earlier VEs
The wiring breaks, rendering the loom inoperable
Part is 92257573 but double check - was around $60 and was very easy to replace
