AC Noise in Cabin - High Pitch Noise
yor71
1991 VN V6 LE Sedan
Hello all out there,
I have just joined the forum and am chasing some information. Yorti (Yor71) is making a high pitch noise that is heard in the cabin when the AC is on. Turn AC off she goes away. It is not temperature related, speed related or load related. Sometimes it will happen and sometimes it won't. Anyone else heard this noise or anything like that? It is deffinantly not a P/S whine (I work for Ford:whistling and know what they sound like). Very annoying noise would like a little direction if anyone has it.
Thanks alot
calais_cruzin
Calais_Rattling....
Gold Coast
92 VP Calais 3.8
is it in the dash or is it comin from outside.
I sumtimes get a squeel in mine, wack the dash a few times in couple spots n it stops, i think its like a air accuator closing up n the air still being able to jst get past, good hit n she opens.
My noises come outta the middle vent...
Mine will do it ac on or off, soo yea
not sure if that helps at all
yor71
1991 VN V6 LE Sedan
Thanks for the quick post buy its not a wind noise or anything its like a high pitched electrical squeal. Deffinantly inside of vehicle and just suspect centre of dash behind radio.......
camstatic
I'm back babeh.
Regional SA
VZ SS
Does it come and go with the compressor cycling on and off, or is it related to the blower motor?
yor71
1991 VN V6 LE Sedan
Doesn't change when AC cuts in and out and changing speed of blower motor doesn't change it
FXST01
The Grey Man
Perth, WA
VP V6 Exec
like a high frequency squeal? Because I have that too.
camstatic
I'm back babeh.
Regional SA
VZ SS
Sounds like it could be the whistle of gas through the system...
yor71
1991 VN V6 LE Sedan
Nah not a whistle of gas it is like a high pitch frequency like a piece of electronics is making the noise - very bizarre and annoying.
rob drag racer
vn vp drag nut
golden beach
forums.justcommodores.com.au
vp 3.8 with gas new project vn s1 guted strip only
i have the same issue
mine starts to get a high pitched sequel after a few minuets from under the dash stops when the ac compressor kicks in or out i was told by an ac repairer it is most likely due to the ac being a touch low on gas causing tiny vibrations through the piping under the dash and not to be worried its common
having said that in summer it can bring a huge migraine on but who cares when its hot as long as its cold i don't complain :thumbsup: :thumbsup: :thumbsup:
