adding cold air intake to VS V6
jafo
lurker since 2003
59
adelaide
1999 wh statesman
instructions on adding C.A.I on VS V6.
parts required to do job as follows
Inlet assembly
#: GM-92053315
Duct to air box
#: GM-92053314
Bottom assembly of air box
#: GM-92053006
drill
screwdriver (rivet gun if using rivets)
and new air filter if needed
  1. open bonnet
  2. undo clips on airbox and lift up
  3. remove air filter
  4. remove 3 screws in bottom section of airbox (if replacing this section)
  5. lift out bottom half of airbox and put aside
  6. take new section and clip in the ducting to side of new box (just pushes in)
  7. place new section where old one was and replace the screws
  8. place the inlet over the top of radiator and connect the ducting to make sure you have a good fit
  9. make marks where you have to drill the holes in the radiator shroud with pencil or similar.
  10. remove inlet
  11. use drill to drill holes in shroud (remember not to drill no more than 1/2 inch through shroud)
  12. place inlet back on ducting
  13. and screw or rivet inlet to shroud
  14. replace air filter
  15. place the top half of box back on bottom half of box
  16. do up clips
  17. start engine and check all is fine (IE: no leaks around box)
close bonnet job done.
jimmy_jd_25
Jimmy - VS
in my house
VS Equipe
costs?
just wondering if anyone who has done this...or anyone else who is in the know, could advise me as to an estimated budget i would need to work to to set up a cold air intake system such as the one described above?
ta.
jimmy
mattman
'00 WH V6
It's around $55 for the scoop and chute, another $35ish for the pre-made bottom half of the airbox that suits, but you can do that yourself if you are keen.
Parts are readily available from holden spares, or from ebay...
Andrewing
Any chance of a guide for pod filters? Or can someone tell me how they sound?
pow3rslave
DoNothing Member
eastern subs, vic
VP 5.0L
pod filters sound louder, but general opinion has it that they lose power rather than gain, unless done super pro (in a box or so on) heat shielding's of the pod's an issue, you seem to pull hottish air from in the bay.
DannyboyDS
Just hand me the pliers.
39
VS Berlina
I have a V6 VS berlina Ecotec and i'm putting a piod filter in this weekend hopefully, ill be encasing it within the box and fitting a cool air intake,, it requires a slight modification to the box,
I.E adding a small joiner pipe into the box which protudes on the interior and exterior.
Basically it makes everything fit nicely and joins everything.
Maybe i'll post some pics and a guide to how I did things.
jiff
Tasmania
jhphoto.tk
1994 VR series 1
Did you end up doing it i would really love some pics before i go out and buy anything.
VS_Pete
Donating Member
Hi jafo
No.13. and screw or rivet inlet to shroud
What size screws do you use and do you use washers with them?
Have you got a pic. of them?
P.s. getting lazely in old age.
