Adhesive removal!
Discussion in 'General' started by toks238, Nov 4, 2012.
  1. toks238
    toks238 New Member
    Werribee
    VZ executive
    Hey guys. I removed the plastic panels on the outside of my VZ. I Can not remove the adhesive though!
    I have looked around on the internet and tried everything I could find and nothing worked. I got some adhesive remover and still nothing. Has anyone got any idea how to get it off?
    Cheers.
  2. ephect
    ephect Donating Member
    VS Acclaim V6
    What exactly have U tried?
    So the threads on JC haven't been helpful?
  3. toks238
    toks238 New Member
    Werribee
    VZ executive
    I tried terps, WD-40, cooking oil, vinegar and then the adhesive removal. A car detailer just looked at it and wont try it because he thinks if he tries it will remove the paint as well.
  4. TinSnips
    Hills District, Sydney
    VF SSV Ute
    What colour is your car and what type of adhesive is it? Pics?
  5. ephect
    VS Acclaim V6
    depends how thick the adhesive is, if its thick use a razor blade to thin it down, the purchase a caramel wheel, and take ur time so U don't burn ur paint
  6. toks238
    toks238 New Member
    Werribee
    VZ executive
    Its a sky blue and I used goof off. Ill take some photos now though.
    I used a blade to try and shave some of it off and scratched my car a number of times.
  7. toks238
    toks238 New Member
    Werribee
    VZ executive
    Tried to upload photos but it says they are too large :S
  8. TinSnips
    VF SSV Ute
    use a hosting site like photobucket and link them.
    domestic adhesive removers aren't very strong. It's likely you'll need something stronger.
  9. toks238
    toks238 New Member
    Werribee
    VZ executive
  10. Jonno
    Jonno :)
    Vic,
    fixed links for u
  11. Carl
    Carl New Member
    NSW
    Crewman VYII SS
    I bought a black fender for my Crewman, and it had that plastic prick of a plastic strip down the side of it. I used fishing line and kerosene when I debadged the Chev badges the previous owner put on it, and tried for this too.
    Nope. I ended up having the snap off all the plastic and used a razor blade to scrape off the rest.
    I did however, peel some paint off with it. Which was annoying.
    Mine was stuck on with black sicaflex. Very tough stuff.
    I even went and bought some special silicone remove, and it didn't work...
    By the way, your photos don't work. =S
  12. Carl
    Carl New Member
    NSW
    Crewman VYII SS
    That's the same as what mine is stuck down with. I asked Holden what they used and it's all the same stuff, I was told to use a caramel or vanilla wheel...
    I only had to do one guard. I couldn't do the whole car! Good luck!
  13. greenacc
    greenacc Searching for the billion
    VE Berlina
    that's not just glue dude, that's rubber ! The only things i can suggest to get that off are Kerosene, Xylene ( ie paint thinners ) , and or a heat gun to melt the glue.
    The Xylene and heat gun could strip / melt / smudge the paint and start a fire, so don't mix heat and solvents. Nothing less strong is going to get it off. I'm surprides the acetone didn't work.
    Good Luck !!!!!
