Adjusting Bands.
J_D
Ipswich. QLD
VN S1 and VS V8 Statesman
How do you adjust the band/s on the VN. I dont have a Gregories manual so any help would be appreciated.
D
darby253
Guest
On the drivers side of gearbox there is a cover approx 60-80mm diameter.This cover needs to have the spring clip removedwhilst being pushed in.Care should be taken as it is under spring tension and may fly out once clip is removed.If it feels like it is slipping it is more likely the friction plates are shot.
J_D
Ipswich. QLD
If they are none adjustable that should save me a bit of time doing the tranny service. Im not having any problem with it I just thought I would adjust it while im there.
s0sage
Posting aimlessly ..
39
MX6 - Turbo .... so flame me
change your oil, do your kickdown cable and call it a day.
J_D
Ipswich. QLD
All done. The fluid was pretty dirty. Shifts a lot smoother now. Idles better too.
cracker
35
yeah cant adjust the band just do oil filter and maybe play with kick down
darby
vp 5.0l
the band is adjustable by shimming or removing shims from servo piston engaging pin
