Adjusting Koni red shocks VK commodore
sire01TMK
47
DARWIN, NT
84 VK 308
Hi all,
Did a search but couldn't find what I'm looking for. I just purchased some front and rear super low King springs and Koni red shocks to suit the VK and would like to know what other people's experience with setting up the shocks as they're adjustable. I have heard conflicting stories about how to set them up correctly and seeing that they're the red ones they can only be adjusted off the vehicle so don't wanna keep putting them on then having to take them off again numerous times to readjust. Some people have said set them to the hardest setting and others have said the softest setting? I have heard that setting them to the softest setting is the go and over time as they sag you adjust them to a harder setting to bring them back to where they were when you first put them in, is this right?
Any help his much appreciated. Cheers, Stokesy.
vc commodore
Like the Leyland Brothers
VC, VH and VY
You set them to how you want the car to ride...A stiff ride, hard setting...Soft ride, soft setting.....
So it's upto you how you want the car to ride from that
sire01TMK
47
DARWIN, NT
84 VK 308
Thanks for that. I've heard that setting them up hard from the start wears them out quicker?
keith reed
76
Raceview Qld
1983 vh v8 sle 2000 vs v8 ute 2012 ve11 redline
Koni say settings are intended for wear though they can be used for stiffness but why would you bother.
Vin999
SA
VSedanS
The super low King springs would be stiff enough :)
Go for the soft setting if you value your lower back.
shane_3800
35
places
vr commo
Just set them one off softest. From memory theres 7 or 8 clicks so not much adjustment anyway.
