Adjusting power steer belt
shanhsv
Luvo
Muswellbrook, NSW
VSII Calais V6 & VSII Senator 215i
Hey guys(and girls),im having trouble trying to how out how to adjust my power steering belt,can any1 help
hako
Donating Member
80
Toowoomba SE QLD
VS11 BT1 V6
According to the book, you loosen the idler pulley locknut and move the pulley in/out to increase or decrease tension. If you've been doing this you may have the wrong belt.
BlackVXGTS
Melbourne, SE
I use a piece of rope wrapped around the base of the power steering pump pulley. You can take up the tension with your left hand and pull the rope to the left while tightening the top bolt on the power steering pump cradle with your right hand. Then let go of the rope and tighten the other two bolts. Easier if you have two people, one to pull on the rope and the other to tighten the bolt. Others have said that you can take up the tension on the belt using a large screwdriver but I've never been able to work out how to do that.
