EYY
- Mar 6, 2011
- 5,754
- 2,036
- 113
- Location
- Vic
- VS Statesman
Charge voltage is load dependent. The alternator is independent to the engine management system and cannot be altered. The only thing you can do is make sure that the load sensing wire (white wire) is in good condition that goes to the battery and make sure all earths are good, including pcm earths. Look at a wiring diagram for the VR PCM to determine your earth wiring.
Plug your computer back into the car, turn all lights on, heater fan on full, wipers on etc and check the voltage. If it drops below 12.6-12.8 with that load then I'd be concerned.
The first thing i'd be doing is looking at that o2 sensor issue.
