SteveSX6
- Feb 22, 2009
- 2
- 0
- 0
- VZ Adventra SX6
Hi guys,
I've got a 2006 VZ Adventra with what sounds like a rattle in the diff.
The cars done 140k which puts it outside of Holdens warranty period.
The rattle comes in on slight overrun, such as when you are coasting down from around 100km and comes on pretty strong around 20-30km,
It disappears if you shift the transmission in to neutral, or downshift, or accelerate slightly.
The noise is constant regardless of whether the vehicle is travelling in a straight line or cornering which to some extent rules out the cyclic know issue that these diffs are known for - the Holden service bulletin specifically lists slaloming the vehicle whereby the noise should disappear or reduce if it is the cyclic knock - this noise remains
Best description of the noise I can come up with is as if there is something loose rattling in the diff housing. The noise can also be felt through the vehicle.
The noise is speed related and slows as the vehicle slows.
The local mechanic has been through the more obvious possibilities and checked wheel bearings, inner and outer cvs, universal joints, diff mounts, tyres.
They have also had the back off the diff to ensure that there was nothing there that shouldn't have been.
They did however find brass or bronze fillings in the bottom of the diff housing.
Do these diffs have a set of shim washers that could have worn allowing some float in the diff?
Any other suggestions would be welcome as I am scratching my head on this one.
Steve
Steve
