Advice needed RE: Camber
And_ROOS
Mornington Peninsula
HSV +6
One place has told me $400 gets me a 2 point camber kit and wheel alignment, someone else suggested that a VZ rear end is the better option however i have no idea where to find one, let alone the cost that will be involved.
The issue is the camber is seriously eating my wheels and needs to be resolved soon.
Anyone got any suggestions?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
I can do you a 4 point camber kit for $175 plus postage.
The VY or VZ will do as they have adjustment, but if it is out of the range of adjustment in them you will still need a 2 point kit.
gsxrdan
Has this got a turbo?!
adelaide, southish
93 VP Excec; 95 II VR Equipe; 99 VT Exec
Whats the kit comprised of? Curiosity only! I replaced my left rear carrier and the replacement had an adjustable tie rod, but theres nowhere to bolt the inner end to on my VT?
glowworm
vt exective
Mate i had a 2 camber kit put into my VTS2 as i had the same problem, now its all good just get a regular wheel alingment and no problems
wrx884
WA's ASR Rep
VT Exec/ VT L67 Spac, 5L VP Calais, 77 TC Gemini
is that the super pro brand Bjorn???
callum_88
Donating Member
Salisbury Downs, SA
VT Exec 5 spd/ VZ SS 6 spd 6ltr
eh what does a camber kit consist of? and where do you put it?
i do know what it does though
jazza15
Jarryd
Eltham North, VIC
1999 VT II S
Camber kit replaces the standard (soft) trailing arm bushes with firmer and adjustable ones. There are two bushes per trailing arm.
And_ROOS
HSV +6
series 1 vt, no matter what i do be it a 2 point or 4 point kit ill have to pay a place to put them in.
Can anyone tell me what the difference between a 2 point and 4 point is? Im guessing that one is a better reducer of camber wear then the other?
Not_An_Abba_Fan
Exhaust Guru
Bunbury, WA
Strange Rover
The brand is Super Pro.
They consist of four adjustable bushes that replace the inner control arm bushes on the rear suspension. They give you toe and camber adjustment. It's not really hard to fit them, just time consuming, as you have to remove the lower control arms to fit them.
