advise
Discussion in 'VY Holden Commodore (2002 - 2004)' started by nicommo, Jul 10, 2015.
  1. nicommo
    nicommo New Member
    shouldhaven
    2003 vy commodore s
    Hey I have a 2003 vy. is was recently in an accident and has some front end damage it needs the radiator support and other things replaced just wondering how much work is involved in doing so?
  2. commodore665
    commodore665 expat Saffa
    New Zealand via Cape Town
    2005 SV6 & Alfa Romeo 156 V6
    any chance of some photos ?
    welcome in as well
  3. nicommo
    nicommo New Member
    shouldhaven
    2003 vy commodore s
    Hey kinda new to this site. Not to sure how to post up a picture my phone wont let me.
  4. VS 5.0
    photobucket mobile app is one option.
  5. nicommo
    nicommo New Member
    shouldhaven
    2003 vy commodore s
    My phone is temperamental. I think im just going to to ahead with doing it. Will just be a learning curb. Pictures dont really do it justus anyway.
  6. dgp
    dgp Well-Known Member
    VF II SSV Redline
    Good on you for having a go mate.
    Just FYI, it is learning curve, not taking the piss, life is all about learning.
  7. Jxfwsf
    Jxfwsf Well-Known Member
    Aus
    commodore
    Buy front cut from wreckers, remove panels needed from front cut.
    Remove parts from car that need replacing, weld it back on.
    As simple as it sounds, hope you have a mig welder and know how to use it.
  8. nicommo
    nicommo New Member
    shouldhaven
    2003 vy commodore s
    Yeah. A learning curb for sure. Ended picking up a vz wagon with a blown motor for parts.
    Last 4 days iv been working on the cars. Removed bonnet, gaurds ect off both cars.
    Both top radiator supports are of. Today I started straitening the rail was pushed back.
    Once iv finshed that just have prep for the new support to go on bolt it on. Then test fit everything to make sure it all lines up right. Weld it in place.
    Hardest thing so far was finding some spotweld drill bits. I would have uploaded some progress pics ect but my phone just wont have it. When im finished the car and work out how to upload some pics il be sure to do so. If anyone would be intereated in looking
  9. MYVESSV8
    MYVESSV8 Well-Known Member
    Brisbane/GoldCoast
    VE 6LT M6
    would be nice to see your efforts
  10. nicommo
    nicommo New Member
    shouldhaven
    2003 vy commodore s
    Yes would be good to share. When I work it out il put some pics of progress.
    Today put the support in place ( still not welded ) just to trial fit all penals and see of it all lines up.
    It seems to be alright sits abit lower on the driver side where the impact was. Either the rails pushed down or the skirting is damaged but its nothing to bad. See ifI can fix it up tomorrow amd maybe have it welded in.
  11. Jxfwsf
    Aus
    commodore
    This is the type i use, found drilling a small pilot hole first works best.
    HSS 3 8'' 10mm Spot Weld Welder Drill Cutter Free Postage | eBay
    You can regrind a 10mm drill bit similar to a brad point but angle the outer cutting edge more so it only cuts into the top layers but really isn't as easy as the saw type.
    Double/triple check around the top of the tower if the rail has been bent, it is a weak point (crumple zone).
    All depends how far you're willing to go with the over grown mechano, lots of good professional videos on youtube.
    Here's a couple of major ones for ideas (hopefully yours isn't this drastic):
