After market headunit problems
Discussion in 'Car Audio' started by Ganzer, Aug 5, 2005.
  1. Ganzer
    Ganzer New Member
    VZ S UTE 175 M6
    I have VZ S ute and had a pioneer headunit install, but now i have lost most of my options menu. the menu is the one when you start the car and push the arrows. has anyone else had this problem.
    things missing headlights off delay, h/l appoarch time, auto h/l sensitivity, courtesy lamp timeout, ingition off courtesy lamp, intermittent wiper speed, two stage unlock, door lock indication and last one accessory control. they are all the one i dont see anymore,
    so this thread is for people who have had aftermarket headunit installed.
    what type of headunit and does your options menu have every thing still.
    thanks for any help :ranting:
  2. Tasmaniak
    S.E. Melbourne
    They were all controlled by the original headunit. Well, not controlled as such but it was a vital peice of the chain.
  3. Ganzer
    Ganzer New Member
    VZ S UTE 175 M6
    Holden doesn't even know what wrong
  4. Tasmaniak
    S.E. Melbourne
    Seen it time and time again. Holden understands Holden, not Blaupunkt.
  5. Spyder
    Spyder Guest
    is this the same with the eurovox in the vx's???? i hope not
  6. Tasmaniak
    S.E. Melbourne
    No Slightly different with crapovox
  7. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    I Had a pioneer unit installed in my VY and have not had any problems, I made sure that I turned off the stereo display before the install was done, maybe check this and see it that was done???.
  8. Morgasshk
    Morgasshk Morgasshk
    VY Exec 3.8L Sedan 9C1 Pack
    hmmm, sounds scary, I'm about to buy a VY Exec... and want to install a bigger mp3 player (or dvd screen, depending on funds, fingers crossed!)
    I'm guessing you had no problems with the install either VY2ENJOY?
  9. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    Morgasshk, I had no problems at all, the only thing I lost was the use of the steering wheel controls (which can be fixed with a CAT device, but I didnt want to pay the $200 at the time but i am thinking about it now) and I lost the stereo display on the dash, which only showed volume, radio station or CD number, I lost no other functionality in the car or the dash disply, replaced all the door speakers as well as a 10inch sub in the back (I have a wagon), Mate dont be put off, I was to start off with but you will find most people are guessing about things!. Find a good installer (I had my head unit installed, and did the rest myself) and you will have no worries at all. Like I said make sure that you turn the display off in the dash (via the start up menu) before the install and you will have nothing but loud crisp sound!.
    Hope this helps
    Enjoy.
  10. Morgasshk
    Morgasshk Morgasshk
    Appreciate the advice mate.
    I'll just do the Stinger/CAT adapter at the same time, should be fine. :)
    Have a good one.
    Morgasshk.
  11. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    wgs150, have you tried the Restore Factory Settings and seen if they come back?.
  12. VY2ENJOY
    VY2ENJOY New Member
    VY Family Truckster
    Try this
    wgs150, I was stuffing around with my options menu last night and noticed that when you press the menu button to go to the mext item, I had to hold it in for a couple of seconds and it changed when i released the menu button, give this a go and see what happens. Let us know of your out come, as it has me quite intrigued.
