Air Bag Light???
Jamie_87
2003 BA XR6
Hi all, got another problem, when i was replacing a few globes in dash on w/e, as soon as i put dash back in , i started the car, all the reds came on then the air bag light stayed on. Could i have bumped anything whilst putting dash back in , or is it just a coincidence that the airbag sensor decided to crap itself at the same time?? Is there a way of checking the air bag sensor or do i have to take it to holden?
Hate the fact that whenever i fix a problem/s on the car, more start, fixed the fuel pump,camber,exhaust and dash globes now i got no climate control lights, air bag light on,leaking power steering fluid & bit of oil and transmission fluid!!!
thanks guys:thumbsup:
Jamie
Stretchomatic
34
Ardlethan, NSW
www.facebook.com
86 VL Berlina M5
i doubt it would be stuffed, i had the same prob, i was putting in new speakers and interior light stuff etc etc, i'd think it was when i took the battery off...just took it down to the local mechanic (hes got all the computer diagnostic gear) he reset it and i havent have a prob since.
LisnM8
VS Statesman 5Litre
My air bag light goes off and on like a christmas tree sometimes........anyone know the solution to the problem......
Jamie_87
2003 BA XR6
ahh k , well im going to see my mechanic on sat about the other stuff, so ill ask him to reset mine and see if it works... thanks for the info mate!
kopper69
37
VRII Acclaim
Checked fuse? Relay? You may have just shorted out a wire causing the fuse to blow. After you have checked the fuses, check the bright yellow connector near the fuses (interior) . It is the air bag connector wire, may have come a bit loose. Disconnect your battery for 5 mins and reconnect it. And do it before you go paying someone $.
Doctor Bob
Grandpa
Retired
RG. Colorado & Caravan
I think you will find you have turned the key on while the dash is out, this will log a code in the SDM for the warning light circuit, it needs to be cleared with a scan tool.
After having these problems after "fixing" something maybe you should get some professional help.
Rob
Jamie_87
2003 BA XR6
i think ur right n the ball doctor bob, bcos when the dash ws ou i did turn the key and start the car,ill get my mech to reset on w/e ...thanks for that mate!:thumbsup:
Jamie_87
2003 BA XR6
kopper69 will check that out 2moz morning before work, like u said better off seeing if i can fix before i go paying sum1 ...thanks mate!
