ThankyouNeeding to regas doesn't always mean there is a leak in the system
The aircon system can and will loose gas over time (usually years) and it will need to be regassed
If it looses it's charge quickly you will definitely have a leak somewhere
A leak would be identifiable if the aircon goes from blowing lovely cold air, to blowing warm/hot air over the space of a few days to a week
need to check before using dye some parts manufacturers won't warrant parts anymore if dye is used. Your aircon tech should know if he can use dye or not.Yes it means you have a leak. Have dye put in to find the source of the leak when you have it regassed.
Dye’s never a bad idea imo. If you don’t use it you’re just guessing and will likely cost more in the long run. A/c components are cheap. I just got a brand new condenser, receiver drier and all o rings for under $140.need to check before using dye some parts manufacturers won't warrant parts anymore if dye is used. Your aircon tech should know if he can use dye or not.
