Fu Manchu
- Mar 18, 2006
- 17,948
- 22,640
- 113
- Location
- WA.
- VZ Crewman, VZ Cross 8, & ya mum.
So, when it's cool, the AC runs as expected. Cold air comes through, nice and crispy, fan on 1 does the job.
When the temp gets to around 30-32º somewhere, the AC starts getting warmer.
When it's proper hot outside 40º the AC is about coolish to ambient in temp and the fan goes on full.
When this started, a noise also started.
It's not really there at idle. With revs it is.
A whine a little like a distant super charger.
Ac does run an unusually high pressure (had it checked when we had the VE re-gased). Maybe a clogged receiver/drier? Gas is not low.
The problem and noise isn't so bad with the AC off.
The car will also run sluggish and use a lot of fuel when this is happening.
Yesterday was about 40º and AC was hardly working again. It cooled off a bit with the seabreeze and turned the fan to 1 and air gets cooler. So time to do something.
Something bugs me about the cause being directly to do with the AC.
No squeaks. Just a whine.
Now if you pop the bonnet, it's not going to be easy to listen to the accessories and get the sound. Get some load on things with driving and you'll hear the whine. (Not the passengers)
So I've had an issue with starting difficulty and had a bad battery diagnosed. Things have been going ok since. It hasn't been too hot though. Car has been running great. Low fuel use, then the heat and bam, fuel up, power low, ac warm-ish, whine starts.
So in view of how the AC works (I get the basics, not the detail), I'm putting load on the electrics with full fan, compressor working harder, radio on, car accelerating, air goes ambient-ish.
Have I got a slowly dying alternator?
I did notice a smell after I parked the car, it smelt like a road works kind of smell, but I don't think there was road works (bitumen) going on near by and it was localised around the car. I dismissed it after hyperventilating while smelling around the house for the smell. It went away.
With load, would the ECM being cutting out the AC as voltage gets low?
Faulty alternator when it's hot?
AC clutch slipping with low voltage?
Would the AC put enough load on the alternator to really work it that hard?
What your ideas?
What your ideas?
