calais_SC6
- Jun 10, 2009
- 95
- 0
- 0
- L67 VS Calais
l am going back to the mechanic in the morning, but he said he will already charge for putting gas in, and the problem is still there?
Hey all,
The airconditioning on my 96 Calais is playing up, I've been through some of the above posts and found others with the same issue but I didnt see any fixes.
When I turn on the aircon it seems to have plenty of pressure behind it and seems to be plenty cold, however I cant seem to get the 'head' vents working, it will only blow out the feet or demist, I've fiddled with the climate control.. When I set it to head only I can hear it blowing but it doesnt come out of the vents.. that said I've had it blow out the head vents once, Im not sure what made it work but as soon as I changed the setting to feet/head it stopping blowing out from the head vent again.. no matter which setting combination I use it still wont vent from head
If anyone could post a fix and/or cost I would very much appreciate it
I'll have another look, thankyou.
when i have the either the heater or aircon on when i accelerate medium to fast the air that blowes into your face or whatever other setting you had it on changes to blowing on you foot.The controls arnt moving it just changes direction automatically. Then to get it back to the original setting you have to back the car right off. Also it changes when you just have the ignition starts of on the setting that you want the changes to blowing on your feet. I hope that makes sense. Any ideas of what could be. Thanks
heyas, read on the thread that VS ac's dont need to be regassed? Tried turning the fan on on the one i just got and its only blowing air. no cold air. Is there anything I should check? I'm pretty sure its got A/c though.
Hi - just noticed an old post of yours re aircon probs - I have a similar thing happening - do you remember what you did to fix it - vacuum lines??? or was it something else??when i have the either the heater or aircon on when i accelerate medium to fast the air that blowes into your face or whatever other setting you had it on changes to blowing on you foot.The controls arnt moving it just changes direction automatically. Then to get it back to the original setting you have to back the car right off. Also it changes when you just have the ignition starts of on the setting that you want the changes to blowing on your feet. I hope that makes sense. Any ideas of what could be. Thanks
