efryer
- Sep 16, 2005
- 26
- 1
- 0
- Age
- 59
- 2007 VE SV6 3.6 Auto
VS Air direction Selector
Not sure if you have it fixed yet, but sounds like the Air Selector unit is screwed. I had a similar problem, where on certain settings it sounded like a light hissing sound (although one setting was louder), and the vent was either stuck in one position or not the position you selected.
I was expecting the worse e.g. megabucks, so I held off fixing or even looking at it for a while.
Anyhow, spoke to a Holden spare parts guy and he said straight away (common issues as you said), that the selector was crook. Went in and picked one up new for $26.00 (it is just the backend part), just moved over hose for hose (5-6mm hoses) and worked fine, all back to normal.
From what I could see, the selector works on little chambers directing the vacuum, which in turn moves the air-flow flaps, and if it is slightly warped or leaking in a spot, the vacuum becomes a random or non-event.
Hope this helps someone
Regards
Bob
Craftsman said:On my VS the dial doesn't work at all. If I have it set to face, it blows out the windscreen vents. Sometimes you just get the hissing sound and no air at all. There's no recycled air, all the air comes from outside and that's frustrating in traffic.
Seems a common enough problem, anyone got any ideas?
Regards
Bob
