gsmrobinson said:
Here are some known problems
#1.. The liquid lines at the reciever drier seize onto to the reciever drier. Replacement of the liquid line from the reciever drier to the tx valve. Or the replacement of the condensor or both. Approx. $190 - $500 gassed
#2.. Discharge hose leaking. Hose from the compressor to the condensor. Approx $200 gassed
#3.. Tx valve leaking. Small valve that regulates the gas flow. Approx. $200
#4.. Evaporator leaking. Behind the dash. (Dash out 10 hours) Approx $850
#5.. Condensor leaks. Normally top left hand side. Approx $500
#6.. Liquid line leaking at P' Clamp on condensor. Approx $190
#7.. Compressor leaking or self distructing. Approx $1200
#8.. Leaking Heater tap. Causes loss of cooling. Approx $60
#9.. Heater tap staying on. Vacuum switch problem. Approx $50
#10.. leaking on floor. Drain tube blocked. Approx. $20 for deblocking
These are the most common problems I get with the A/c system on VR-S Commodores.
Don't be too scared of the problems, just be aware of them and that The A/c does NOT just need "re-gassing" it WILL have a problem.
Regards Guy.
holy moly....10 hours for a dash removal?the VR -VS's seem easier to remove than the VN's,no offense to you boss,but this is what i was trying to explain to some people here on the forums,a mechanic today will almost double the times to make his money
,undoutbly you have seen on TV in recent times about the automotive industry,especially with women customers.i'm a retired motor mechanic myself,i got out of the trade for this reason,i'm to honest and couldn't work under those conditions,it's just not right.....not specifically targeting you mate,but i'm sure you don't like getting ripped off,and i'm sure you wouldn't like to see some one else get ripped off,thats why i operate from my house now,i can work at my pleasure,not under any stress and charge more than half less than any registered mechanical buisness.it took me 2 hours to remove a VN dash,admittedly i didn't have to put it back in,but 2 hours out,allow 3 hrs in = 5 hours to remove replace dash,now i haven't seen the latest times guide book for years,but 10 hours thats a lot of smoko breaks
