T
the_axeman
Guest
I have a 1999 VT Series 1 Commodore and the air conditioner blows a white mist with a dry smell to it.
Now, it only blows this mist after the car has heated up when you change the heat settings from full cold to something warmer. If you put it back to cold, once it has cleared all the mist from the vents it stops again.
I have had the gas pressure checked and the AC has had a full Holden service and they could not find the issue. It is not over gassed as it is not building up moisture or anything. All settings are perfect.
The water outlet is also clear and has never been blocked.
Can anyone suggest what this problem might be or has anyone seen this problem with their VT ?
