air conditioning
clinker42
64
Hi Guys
VT V6 Air conditioning isnt working. The compressor electric clutch is not engaging. There is no power in the connector that connects to the compressor.
I applied 12 volts directly from the battery and the clutch works.
Where would the probkem be, have checked the fuses and relays and made sure the fan is on and the A/CON SWITCH IS ON AS WELL.
Your help would be greatly appreciated
Thanks Trevor
accentstencil
72
Caboolture South, QLD
WH II Caprice, 5.7 2018 Equinox LTZ V
Could be low on refrigerant. I think there is a pressure switch that stops the clutch from engaging if there is insufficient refrigerant.
