Air flow direction changer problem
vxseries1
VX Executive S1
Hey all,
I have a 2001 vx commodore and recently the nob that changes the direction of air flow (face, feet, front demister, etc.) has stopped working. :cry: It's stuck on the front demister... I've tried replacing the whole cluster but still no luck.
Any ideas at what might be the problem?
Any help would be greatly appreciated.
Thanks
vxseries1
accentstencil
68
Eschol Park, Sydney
WH II Caprice, 5.7 2017 Captiva.
Make sure that the thin vacuum hose is connected at the rear of the intake manifold.
vxseries1
VX Executive S1
this might sound stupid,
but can you give me some instructions or better yet pictures on how to locate and check for this vacuum hose.
much appreciated,
vxseries1
1BEAST2NV
Perth N.O.R
08 (MY09) VE R8 6.2ltr M6 475rwhp
its behind all the dials when you pull the main plastic facia off (around stereo and dash). the dials are still screwed down (hot/cold, fan ,dials), undo the main dial control and the vacuem line should be behind there along with other ones aswell (face,foot,demister) etc...
accentstencil
68
Eschol Park, Sydney
much appreciated,
vxseries1
Here you go. Also check the check valve, it's a one way valve, which means you can blow or suck through it in one direction but not the other.
vxseries1
VX Executive S1
that was it :D
thanks so much I finally have air con :)
