Air-flow of V6
sgo
70
vp
Can anyone tell me how much air a stock V6 sucks, (cu.ft/min ?)
as I want to use a non-stock intake/filter and would'nt want to restrict the flow.
fazz1977
myspace.com/fazz_himself
44
Frankghanistan, Melbourne, VIC
www.buttonhole.com.au
1992 VP Executive Wagon, L27 V6 3800
Do your math and you should be right. Generally speaking a larger air box, intake and filter will flow higher than stock. ALWAYS a good thing.
VT-565
QLD
VT
i think it is up around 650cfm @ 5000rpm...
very rare for an automotive air filter manufacturer to give you a cfm rating though.....good luck mate
jules
we like the bun
pimpin
a couple of quick calcs and i get 332 cfm at 5000 rpm for 3.8 litres at 100% volumetric efficiency. it's probably around 300 as it won't get 100% efficiency.
VT-565
QLD
VT
convert engine capacity to cubic feet and multiply by rpm=cfm
3800cc = 0.1341957cubic feet x 5000rpm = 670.978cfm at 100%VE
jules
we like the bun
pimpin
yeah but being a 4 stroke, it only takes in air every second stroke, so you need to half that and you'll get my figure :)
sgo
70
vp
Thanks all for the info. and the maths lesson.
(I did see some some filters in a shop that had a rating of 600cfm on the box.)
VT-565
QLD
VT
ha ha ha....apologies.
need to up the caffiene intake.....however......1.suck 2.squeeze 3.bang 4.blow....thats down, up, down, up then intake on the next down. just for clarification
jules
we like the bun
pimpin
hey you're right.. i should have said it takes in air every second rev :)
sgo
70
vp
filter fitted
Well I ended up using a "Lynx ram-flow 600" filter and works fine, but:
One post in here mentioned their pod being noisy when cold but ok when the engine warmed up, and I thought that sounded unlikely, well that is exactly what my system does!
Also I didn't expect to notice any difference in driving, but it definitely is crisper and has a bit more "go".
Strange, but not complaining.
