lout
- May 13, 2006
- 5,565
- 4,271
- 113
- Age
- 60
- Location
- Langwarrin Victoria
- VXii Executive V6 , VYii Adventra LS1
just test how galahs showedI took mine out tonight and tested it by pushing the rod in then placing fingers over the 2 lines, released middle one (orange) goes halfway and holds till I take my finger off the back one (pink) and extends fully out.
Then tried just the side one covered after pressing it in, that does not hold at all, extends fully out. Then I tried the back one only covered with finger after pushing it in and that stops halfway.
Does that mean it's working correctly?
Do I now remove the center one and test that one, seems to be the hard one to remove?
I read that the control bank under the glovebox can fail as it's a solenoid that controls the vacuum flow to each actuator.
What a pain to figure out. Smoke machine be good right now to send down the line.
if you have climate control, there is actually a third actuator as well
smoke machine would be too cumbersome as you would need to remove all hoses and smoke one at a time,
