Glaze
NSW
VT
Just confirmed that the horn pad I got is faulty since it keeps the horn constantly on. Cleared airbag light with new clockspring and fitted original horn pad on. Is it possible to repair the horn pad? Does the horn pad have to be same part numbers?
lout
61
Langwarrin Victoria
vt-vx hornpad are the same
hornpad contains the airbag, so cant be repaired
should be thousands of them at the wreckers
Glaze
NSW
VT
Part number with “DDI” at the end is the donor part
I got it off some bloke he said he swapped this one out for a HSV one but I guess he lied since it’s faulty? My car is an 02 Calais
Lex
Geelong Victoria
VT Executive S1 V6 6 speed Auto Wagon
None of that matters. They are interchangable.
Have you checked the spring, when you push the pad to work the horn? Maybe its stuck on? Doubt it?
Glaze
NSW
VT
looks ok cant fault it will have will to try with another horn pad this one could be kaput
  • Like
Reactions: Lex
Glaze
NSW
VT
There’s no springs on this one like the VY maybe the contact was out of alignment, is there any way to adjust the horn contact frame?
