uniacidz
Harden the Frak Up
- Dec 13, 2011
- 2,267
- 181
- 63
- Location
- Sideneee
- VE Berlina
Got a airbag light showing up. Turn ignition on and turns off after a few secs then comes on again and stays on.
Rundown how and if this can cause it.
Finally recieved my dash cluster 3 window one and looks like Level 3 (in which surprisingly shows all gears selector lights which also works)
Anyhoos, no airbag warnings before, installed the new cluster to test only and straight away got the airbag warning light.
After checking with my other clusters, removing bcm fuse for 10secs etc and also airbag fuse, the airbag light is still present
1. Could it have been tripped by the level 3 cluster? EG maybe this cluster had been configured for a Calais in which had more airbags then my SS and hence tripped up the BCM?
2. If so wouldnt the removal of the BCM fuse reset that?
3. Where to go from here?
Hope anyone can help.
Jase
Jase
