aircon fittings rusted on?
Jasminka
Mandurah
Cerise Caprice
The aircon isn't very cold, so I call up a mobile service. He came out and said that filter-drier needs to be replaced, unfortunately it is rusted, and odds-on can't be removed without damaging the condensor or pipe. So he dosed it with penetrating oil, and said he will come back next weekend to try get it off....
Is this seizing of fittings a common problem?
losh1971
North Tas
VE Series I SS Ute
Very common. Chances are the condensor and pipe will need replacing at the same time.
krusing
Melbourne, Bayside
If you have room around the pie fitting, and if you can tap the pipe nut on both sides with 2 hammers, that will shock the fitting, you will be able loosen it a bit easier.
Also best to use a slit ring spanner for pipe fittings.
wamboin23
Donating Member w/ Boost
34
Wamboin, NSW
VS Calais - Cooled L67 + T56 | VF SSV Ute
The main issue is the aluminium fittings corrode, and will fall apart as soon as you put a spanner on them.
I'd be getting a new condenser and liquid line fitted as well, cause it is pretty much guaranteed to fall apart.
Vtv64L
Coffs hatbour
Vt v6 4l forced cold air induction
How do you degas the air con yourself need to replace compressor
vs-lover
VS S2 Calais, VS S2 Exec Wagon, VS S2 Acclaim
mmmmm...............just crack it open I guess ?, just make sure you don't have a representative of the EPA behind you.........please. ;););)
In actual fact I'm in the same boat here myself with my sons VS, unless one can change the front bearing without pulling it all apart which I'm certain you can't do.
Wozza
VR_GS commodore
When I had to change the compressor on the VX...I took it to a local re-gas place charged me $20 to properly remove the gas...
My Generation has done enough damage to the planet,besides the Ozone hole is getting smaller so thought Id do my itty bitty part ;)...also the stuff is bad for you so if you go backyard on it please be safe.....
1985VK
Australia
VK SL
Keep oil saturating the fitting and give it at least a week if not longer.
bevzan
54
Redcliffe
VS Ute
use INOX or super INOX worked for mine in 20mins
1985VK
Australia
VK SL
If it works in 20 minutes then it should definitely be ready in a week ...
